Any way to recovering ICQ conversations
I was having an older version of ICQ, I uninstalled it and installed the latest version, It seems my past logs of history conversations are gone, I cross checked through the entire Documents and Settings folder, but I was unable to find the log, Is there any way to recovering ICQ conversations, Please advise.
Answered By 15 points N/A #167678
Hi Wendy,
The Software Informer is used to recover the ICQ conversations for the user.
1) The software can be downloaded from the Software Informer official website
2) It provides good and effective management to the user
3) It has synchronization between the client and the messages
4) The informer services can be used effectively for large data
5) It delivers data that has quality specific to the data
6) It is reliable and scalable for all applications
7) The software helps user to keep the updated about the information different versions available
