Annoying error message keeps popping on smartphone
Hi Trouble shooters,
I got a new smartphone, crazy about it. I am with that always for the first few days of arrival. After some days I started getting this error message often. As of now phone is functioning good, main thing receiving call and able to connect online. But this error makes me irritating, whether I need to update my phone or the apps in the phone. Is this a common bug? Help me find out.
Error Image
Words in the Error Image
ALERT
Sorry, we ran into a system error. Please try again later. If the problem persists, call us at 800-922-0204. Error code – 1
Error Code – 1
Answered By 590495 points N/A #179424
Problem is you did not mention the brand and or model of the Smartphone you have so we can check its operating system and the proper way of updating it. But anyway, if it often gives you an error whenever you try to update the software of your Smartphone, try turning it off, wait for a few minutes, and then turn it on again.
Try updating the handset again and see if it works. Also, before updating your handset, check if your phone can freely access the internet because the update is usually downloaded either directly to your handset or via your computer. If your phone includes software that you can install on your computer and update your handset, install the software on your computer.
Instead of downloading the update directly to your handset, use the software on your computer to download the update and then install it on your Smartphone. This is more convenient since downloading to a computer is much faster than downloading with a Smartphone. Use the USB cable that comes with your handset to connect your phone to your computer. And also, make sure your phone has plenty of space for the update.
