Advice me on traffic light application project ?
Hi Experts,
I am currently working on a traffic light application project. I am looking for sample project similar to my one which has being developed using VB. net. Can you suggest me a website relating to my scenario. It should be a valid link. Thanks.
Andrewjohn
Best Answer by Fraserr thor
Answered By 5 points N/A #159268
Here is a simple tutorial that implements the traffic light system in vb.net. Please visit the following link and you will be well advised by that tutorial.
Hope it helps. Thanks and happy coding.
Answered By 0 points N/A #159269
You are using Microsoft Visual VB .net to create traffic light simulation. It is created Microsoft to make programming easy. If you want to be a good programmer, you should have tried all by yourself.
Here, I give you two code blocs as pdf.
Hope these code blocks will help you.
