No of visitors who read this post: 863
Type: Question
No votes yet
Does Adobe Reader X have something to do with why I can’t be able to download a pdf file from email or any website? I don’t really know why I get an error message upon downloading. The document can’t even be opened after this error. But if I try opening the pdf documents stored on my hard disk from an external device, that’s the only time it would work successfully. Can you please give me an idea on how to really fix the problem I brought up?
Comment viewing options
See that any file can be downloaded from the internet and stored on your hard disk  only if.
1.       The firewall is not blocking the type of file
2.       The web shield to the antivirus shield does not block the file.
3.       the limitation of the browser to download such files.
As such the problem is solved by unblocking such kind of limitations. The limitations are normally not to be brought forward as this may affect the security of the system.
A popup should appear on the browser asking for whether to block or not the file. There you need to unblock it. Install Adobe reader latest version.
