Hi dear,
I am doing work as movie mixer from previous 2 years at one shop. Owner of shot make ghost of the system but suddenly ghost will be lost.
Now I am trying to install Adobe premier but I am receiving one Error.
Detail of Error is here.
Premier Elements Debug Event
Premier Elements has encountered an error.
{….srcComplierMixer.cpp-69}
Please provide me guidance so that I can successfully install this program. Thanks
Adobe Premier Elements Debug Event Error
Hi Mcpheejoness,
I did a lot of research in this kind of error. But nothings answer but this kind of error. If you asking me about this error. Will this error might be in your system. Check the compatibility of the system if your application was suited in your system. Or if not you can try recheck the HD space if you don’t have enough space on this kind of application. I suggest that try any possible ways that might causes this error. It would help you. Please post some good news about this error if you have a solution about it. thanks,Â
