Adobe AIR output could not be generated
I have Adobe AIR installed on my PC. The operating system is Windows XP SP 3 . I did not have any problems installing the software; neither did I have any issues using the same.
Now that I want to generate an output for the same. I keep getting an error message that it cannot be generated.
Adobe AIR output could not be generated. Version=v7.00 (The system cannot find the file specified)
Can someone tell me what I need to install in order for me to generate the output?
Best Answer by Sharath Reddy
Answered By 590495 points N/A #85530
If you are compiling an application using Adobe AIR, your program configurations may have invalid arguments or wrong URLs or file paths. If the application you are compiling needs to load a particular file, try checking again the exact location of the file. You might have specified a different path of the file or the specified URL of the file has typographical errors. Check again all other arguments in your program.
You may also try uninstalling and then reinstalling Adobe AIR to freshen the configuration. If this does not work, try upgrading it if you are not using the latest version. Adobe AIR 3.1 is the latest version and is already available for download at https://get.adobe.com/air/?promoid=BUIGQ.
