Adding picture on Album Info
Asked By 410 points N/A Posted on -
Hi to all,
I am here to get my desired fulfill. I want to add picture in an audio file. Let me clear it. When I playing an audio or media file there is a picture shown in the album info. I want to add my picture or a picture which I like.
But I can not do this. I need suggestion how to do this.
I hope there will be solution for my desire here.
Best Answer by hansi
Answered By 0 points N/A #112268
Hello dear wisher, there is various ways to fulfill your wish. I will tell two ways for you here. The simplest and first way is open the media file with windows media player. Now select the file in which you want to add picture. Right click on this file and click on the option named advanced tag editor.
Now there will be a new window opened. In this window go to the pictures tab. Click on add button and browse for your desired picture. Select the picture and click on apply, ok. Now you can see the picture on the album info of your way.
If it does not work you can use software to do this. For this go to Google and search with "stamp id3 tag software". You get the software easily there. Download it. Now go to the software, select songs. Add picture to songs.
And press stamp. In this way you can add picture to your song also.
Hope your wish is fulfilled.
Both of these ways are fruitful for you.
Answered By 0 points N/A #112269
Here’s another way on how to add picture on your album. Launch mp3 tag.
Select and add the folder where the album is being saved.
Right click the box at the lower left corner of your computer and click add picture.
Save.
