ActiveX setup controls closed due to an unexpected event
I can’t install Trend Micro cause of this error and I don’t know why also I had some problems with downloading. I tried many times and the same error appeared. Any solution ? How can I solve this error ?
Thank you !
Trend Micro OfficeScan Web Installation
Information needed to do the installation has not been downloaded by the ActiveX setup controls due to an unexpected. Please contact your OfficeScan administrator for assistance.
OK
Answered By 590495 points N/A #170590
At first I thought there was a problem with your operating system because you are using Microsoft Windows 8 and not all applications are supporting it yet. But after checking, you shouldn’t have any problem because Microsoft Windows 8 and Microsoft Windows 8.1 are fully supported. So there is really no compatibility issue.
The error message mentioned ActiveX which you can install separately. Normally, it is only Adobe Flash Player that is mostly downloaded by users and installed on their computer. If you haven’t installed ActiveX, it can also be downloaded and installed from Adobe. If you don’t have it yet on your computer, download the installer directly from Adobe Flash Player ActiveX.
If the installation is having problems with the ActiveX controls, I think installing Adobe Flash Player ActiveX might help. Trend Micro OfficeScan includes support for Windows XP Professional Service Pack 2 x64 only, Windows XP Service Pack 3 x86 only, Windows Vista Service Pack 1 and higher, Windows 7, Windows 8, and Windows 8.1 both x86 and x64. For the complete specifications, visit OfficeScan Endpoint Protection.
