Activex ghostscript for viewing PDF files
How can I create an Activex control for viewing PDF files using GhostScript?
Can GhostScript handle multiple Activex processes?
I need help in Activex Ghostscript for viewing PDF files.
I have a desktop with Intel Pentium 4 2.66 GHZ, 1 GB RAM and running on Windows XP 64 bit sp2.
Best Answer by Samuel J Melendez
Answered By 5 points N/A #157248
Dear Anderson Thomas,
You are facing problem about GhostScript and PDF file. Has a better solution for you.
You can visit this site for solving your GhostScript and PDF problems.
Hope you will visit this site and your problems will be solved.
If you have another issue keeps visiting here.
Have a good day.
Answered By 50 points N/A #157249
Hello, Anderson
Hope you are fine. I think I can give you a solution.
Here I give you a name of website where you will find answers on what to do with describing every step.
Step by step description
Hope you will get your answer.
