This action cannot be completed because the other program is busy
Hi Guys, When I try to run technote I don’t know why it gives the following error saying that the server is busy, this action cannot be completed because the other program is busy.
While attempting operations such as Update View, Check Out it is also giving me such errors on some other applications as well. Please help me to solve the problem.
Server busy This action cannot be completed because the other program is busy. Choose ‘switch to’ to activate the busy program and correct the program.
Best Answer by Ramonag jenniferf
Answered By 0 points N/A #139454
Hello Hazelwlee,
When you see this message in your machine "This action cannot be completed because the other program is busy" then simply follow these step to solve this problem.
Open Internet Explorer-click tools-internet options-connections-lan settings-proxy server-advance-delete proxy server settings-click ok-uncheck all boxes-click ok,
otherwise you should try Clean Boot procedure to isolate a possible culprit.
Answered By 0 points N/A #139455
Hazelwlee,
Restart your application in order for you to use the application. The cause of this is, there is a part of the software that is busy in processing or loading components in background. Wait for the application to complete other operations before beginning another operation in the same application. Other cause of this is, the server did not respond to your last action and still busy in your recent action.
