Acrobat Error: “Failed To Load Core Dll”
Hello All,
I downloaded a pdf file and tried to open it in Acrobat Reader. My acrobat application is not working properly and there is an error message: “acrobat failed to load its core dll”. Please help me to fix the problem.
Answered By 0 points N/A #79581
Every application has some library files which are linked dynamically at run time called as DLL (Dynamic link Library). While launching Acrobat reader or adobe reader, the error “acrobat failed to load its core dll” is very common. Don’t get afraid, this is only due to some damaged library files of the application. So try to repair the Acrobat or Adobe. You can try the solution:
1. Go to Control Panel->Programs and features.
2. Select Abode Reader/ Acrobat
3. Click Change option ->Repair. It will start repairing the damaged file.
4. Restart your system. If the problem still persists then try to reinstall the Acrobat Application again
Hope this will help.
