No of visitors who read this post: 167
Type: Question
Author: Alicekdailey
No votes yet
Hello Experts,
I tried to find the answer to fix this problem. When I want to SAVE AS and try to close the AutoCAD LT 2012 then the error message always Pop-up.
Please give me a number of suggestion, solutions and some steps to fix this problem. Already I re-install it 2 or 3 times but the error come out.
Please help.
Thanks in advance.
Comment viewing options
Hallo Alice,
What does the error message say exactly? There could be a number of reasons as to why you are experiencing that. If you are getting the error when you are trying to SAVE AS the application during the download process then it is much likely that you are downloading a corrupt file. You will therefore need to try downloading it from another site and see if it will work properly.
But if you can download it successfully as well as install and then have trouble while using it, it is more probable that the error is occurring due to the following reasons:
  • Some system files needed for the application to work properly may have been tampered with and therefore you will need to run a registry cleanup on your computer to fix it.
  • You can try reinstalling the application and see if that will solve the problem.
Carl
