No of visitors who read this post:
406
Category:
MultiMedia Applications
Type:
Question
Author:
Marlon jimenez
"Track Following Servo Failure” is the error message and no backup of data are happening when I am using AVS Disk Creator. (The Other burning programs that I have also are working fine with my DVD burner.) To correct this error and by what means can you help, please?
Try to update your AVS Disk Creator to the latest version. If you still get the same error message then check whether an AVS Disk Creator is not a single listened product. If you still get the same error, then try to burn at the low speed and disable auto speed detection. Then that will solve your problem. But if you still find the same problem then try the following steps mentioned below:
Make sure your drivers are in DMA. DMA is a high speed transfer rate for ATA devices and is required for optimal performance of your drives. The other transfer setting is PIO which is very slow and sure to cause problems with todays high speed devices. You can check your DMA settings by following the instructions at this link,
