No of visitors who read this post:
284
Category:
Misc Software
Type:
Question
Author:
William s jackson
I am getting an error saying "Error accessing the system registry" as I try to install a new program. I inserted the disk and clicked "run" and the popup is saying the above error.
I have installed it earlier and uninstalled it but again I need it to install and I am unable to do it.
I want to know whether I missed something while installing.
I am very thankful to your help.
You usually encounter thing error because of some software updates, when have new program installed new software added to your system. The reason is some old files during updates or software installation were not successfully deleted to your windows registry. The best thing that you can do to get rid of that error is to delete the old files, start software update to keep also your computer run smoothly. For you to determine what software or process triggered the error, such as newly installed software, software updates. But it is difficult to do it manually, so it much better if you will find registry software cleaner from the internet. You may try this one. http://regfix.biz/
