No of visitors who read this post: 509
Category: Windows OS
Type: Question
Author: Jaycel colis
No votes yet
 I have a 7" wireless book (Chinese) with Windows CE 6.0 rooted. It can not bond to Wi-Fi.  Once I draw it on cmd, it prompt the message “Cannot execute netstart.exe" or some command for that issue. In addition, the message prompts "PPPoE Access Concentrator is not responding". Let me to thank you for your time for helping me to resolve this concern, for I am at my intellects end.
Comment viewing options
# (Solution Accepted)
Hi Jaycel colis
From the message “PPPoE Access Concentrator is not responding" this mean that your 7” wireless book is unable established connection with your router (Wi-Fi). That’s why your 7” wireless book cannot bond to Wi-Fi .From my working experience and research to solve this problem you have to reinstall the router (Wi-Fi) again. Give me the router model then I can tell you installation process or you can contact with your service provider.
For additional, just to let you know the cmd command is netstat.exe instead of netstart.exe.
Thanking you.
Bhuyian
This message “PPPoE Access Concentrator is not responding" indicates that it is not possible to connect 7”wirless book with the router(Wi-Fi). It indicates 7”wirless book is not able to combine with the Wi-Fi bond. For solving the problems you have to reset your 7”wirless book setting and have to reinstall router appropriately. If the problem doesn’t sole then contact with 7”wirless book customer service or provider there may a hardware problem. Then you can change your hardware.
Best of luck
