Hi everyone. Why is that the dell driver Bluetooth 1300 is for Broadcom or widcomm only? How to run dell driver Bluetooth 1300 in Toshiba Bluetooth stack? Thank you so much.
Hello. I need to know how to set up vpn on Asus dsl 10? How to hide my router from others? What kind of problems will I encounter in this set up?
Hi. Where can I find open span runtime? How can I hide this open span runtime while I'm using it? What will happen if the setup is not used properly? Thanks.
I recently migrated to ultra vnc from winvnc. I uninstalled winvnc and deleted the installed directory, after that I restarted the computer. Later I have installed ultra vnc. Now I can use the viewer to load vnc but when I try to save the connection and later on I try to open the connection through file that I have created its giving me the error. I have uninstalled and reinstalled the beta and stable versions but still I am getting the same error. After installation it is showing all the histories of previous connections. Even though it is a fresh installation. Maybe due to something in registry not cleared properly?
Invalid VNC server specified.
- 125 reads
- 1 comment
I had a computer that crashed a while back. I had to reformat my hard drive and reinstall all my applications. But the Photoshop 7.0 application is not getting installed. I keep getting the following message after about 60% of my installation and it stops,
Message sayings:
ComponentMoveData had the following error:
Media Name: data
Component: ICC_Profiles
File Group: CMS_ICCProfiles_Shared
- « first
- ‹ previous
- next ›
