Hi techyv experts,
I am looking for a quick bookmark. Something I can put like a tab on the left of my document, so that I can click it and it can take me to a certain page. I'd like it like a small tab or icon. Is this doable?
- 235 reads
- 2 comments
Hello friends,
I have a huge file that I want to send to my colleague abroad. My yahoo mail won't allow it. How can I send this file? Its 2GB
Can I make two 404 pages for one website in is?
I need one to be for the public and one for a members who log in.
What is the best resolution to encode from Hand brake for iPad 2?
- 234 reads
- 2 comments
I need a macro made. I have a list of cities in a dropdown box. There are 4 cities: Houston, Denver, Los Angeles and New York. When a city is selected, I want the selected city to appear in the cell B14. Thedropdown box needs to be in Column G of the same worksheet.
Next to the city on the cell B14, I want the state to automatically fill in once a city is selected in the dropdown box in Column G.
I want to create a macro that makes a calendar pop out when you want to enter a date in a cell. What do I have to install to make this happen? How do I do this step by step and which version of Excel do I need to have?
- 584 reads
- 2 comments
| I installed MS Flight Simulator and chose to run from CD because it saves my hard disk space. But now when I open a new software it displays "There is no disk in the drive. Please insert a disk into drive D" |
- 325 reads
- 2 comments
I have a Database for MS Access. There is a menu which is provided in a form that allows the user to access the different functions. This includes allowing you to add, change the records as well as the different reports. Before, the users could see only the menu. However, I changed the form for better access. Now, the users can now see not only the menu but also Access and the complete various Access.
I finally decided to use Windows 7 OS after some months of thinking. It is working well at first but when I tried to install my Adobe CS3 to it, I got an error stating:
"E:\Adobe CS3\Setup.exe is not a valid Win32 bit Application."
I need this software and I can use it with Windows XP without having any problems or issues. And also, when I clicked on the Properties window, it will just stop working. Does anyone here who has an idea on this matter? Many Thanks.
- 555 reads
- 2 comments
