Below are Ann tanner's Questions. Did not find what you want
Click here to ask a question of your own
Category: General
Hi Everyone, I would like to have an editor that will help in PHP design in Linux platform. Currently I am using Komodo Edit that is free, open source editor. I would like to have a PHP design tools Linux that is similar to Komodo Edit, which can be available for free. Thanks
I am getting many problems with vbscript hex encode on my web. I need to fix those errors but I don’t know which code to use and how can I write that. Can anybody provide me the right code or the site where can I get it? Thank you in advance!
I would like not to use pivot program monitor rotating making. If to say by other words-is there the way to rotate my monitor without installing the pivot software for that? Please suggest me that way. May be, any other software can do that better?
Category: Mobile Software
I dont know how to do  exporting mms from iphone, please if someone can explain it to me here, i would appreciate it
I have an SD Card loaded with images, songs, documents, etc. But recently I can't access any of it. It could not be open and I think that my SD Card has a virus. How can I remove the virus? Is it even possible to scan a removable device for a virus? Please guide me on removing the virus. I do not want to lose my files. Thanks.
How to add business directory in a website? When you are going to build a website for your business what is the best tutorial videos and ideas that will help me about this? And are business directory needs a php and html programming language to be build?
Category: OS/2 Apps
Just want to ask guys if huawei mobile connect mac operating system is compatible with each other in a way that my mobile phone can access the internet connection.
Thank you experts.
Category: Windows OS
Hi I am just a newbie in this lotus notes, how to create a calendar using this software and how to categorize the colors for example in holidays and scroll bar colors? Need tips and help. Thanks
What are the features I should look for when downloading a free FTP synchronization client? Does downloading the software makes any registry changes?
When trying to install my Ad-Aware software I‘m receiving an error after selecting the language that says “Access Violation at 784C421 in module kernel32.dll” followed by a second message “Access Violation on module RICHED20.dll”.
After clicking OK I receive another message “Line 412: Access Violation on module RICHED20.dll.” and a final error saying “Runtime Error in Install System Error code 1400 Invalid Window Handle”.
I’m using Windows XP Professional Version 2002 SP3.
How can I solve these errors?
