Hi. I need your opinions on Q-Dir. Is it an efficient file management software? Where can I download this software and would it be compatible with Windows 7? Can I work on a folder simultaneously to speed up my work? How does this work? Does it open multiple windows on a single screen?
Hello there. I’m looking for a software that can rename a lot of files by batch. Where can I download the Rename Master software? How do I install and will it be compatible with my Windows 7 64 bit desktop? Does it have an easy to use UI?
Where can I download Folder Guard Pro freeware? What kind of encryption does it use for files and folders? Can it also hide the encrypted files from other users? Will it work on external HDD’s?
I need to make a 2x3 roof gutter. I already have a roof design. I’m having an error of “This does not appear to be a valid path”. How do I use the Follow Me tool in Google Sketchup 8? Do I have to highlight all the extrusion path? I need tips on how to make a gutter using the Follow Me Tool in Sketchup 8.
Hi there. I have a 3D png file and an HD JPEG image. How do I combine my png file with the JPEG file. I want the JPEG as the background image to my png file. I need tips on applying Background To A 3D Model In Photoshop.
- 32 reads
- 2 comments
Hi guys. I just installed emsCharts hospital software for tablet PC. I try launching the app but the program just crashes. What could be the problem? I have the 32 GB Asus Google Nexus 7 tablet that has the Nvidia Tegra 3 chipset, Quad-core 1.2 GHz Cortex-A9 CPU, ULP GeForce GPU and Android OS Jelly Bean.
Hi. I just purchased a new 64 GB iPad 4 that has the Apple A6X chipset, Dual-core 1.4 GHz CPU, PowerVR SGX554MP4 (quad-core graphics) GPU and iOS 6. Can you block gambling sites on iPad and do I need a third party app for this? Thanks.
Hi guys. I'm making my own website using a responsive Joomla template with admin panel. I'm trying to insert a DCR Shockwave media file but I'm having a message of "plug in must be installed". Where can I get the Joomla DCR plugin? I'm on Windows XP. Thanks.
