Below are Estradabrandon's Questions. Did not find what you want
Click here to ask a question of your own
Category: Peripherals
Hello everybody
Digikam is installed along with kipi plugin package on my system. I receive  the following error during trying to batch convert jpg files  to png
Cannot start 'convert' program from 'ImageMagick' package;
please check your installation.
Please help me to solve this problem.
Thanks a lot.
Using Linux, I would like to know the current windows password without resetting or editing it. I would like your suggestions on how to resolve this problem.
While running command line processor “Console 2” for the Windows, why that command appears for a while and then disappears. What is the method of launching that substitute command as it also does not show any prompt line?
I have a Windows Media Encoder on a computer with 2GB RAM and i3 processor with Windows XP SP3. While trying to encode a video, it will be shown at first, but when encoding the audio to keep, the video is missing. How can I fix it?
I have PowerPoint and OneNote already installed on my computer. I also have Microsoft Interactive Classroom Add-in. What version of PowerPoint and OneNote will work best with Microsoft Interactive Classroom Add-in?  And also, is it possible to reinstall this after adding PowerPoint and OneNote when I have previous version installed on my PC?
