Display :
Did not find what you want,
Be the first to ask question on Windows OS
Category: Windows OS
I am installing Windows 8 using Oracle Virtual Box. All the necessary configuration has been done. But I've got this following start up error display:
Your PC needs to restart
Please hold down the power button
Error code 0x0000005D
Parameters : 0x03062502
Any Idea how to resolve this problem?
The feature Do Not Track will be the default for Internet Explorer 10. But will it be possible to switch the feature off? If yes, how?
I have just installed windows 8 on my computer. Fortunately there was no problem, no error message displayed, no BSOD etc. But unfortunately it keeps on restarting every hour and a half without any reason. I hope someone could help me with this problem.
My OS was windows 8, and I've install Real Player latest edition, the problem is every time I launch my real player with video of any length it freeze my computer and there was no information displayed on the page. Is real player latest edition compatible with windows 8?
I am having trouble in uninstalling programs or applications to my computer. I am trying to remove through Control Panel and then Add/Remove Programs. I always succeeded in removing those programs but the problem is when I restarted my computer, those programs I already uninstalled are still visible and is still installed. It applies to any folder and files in my back up. How can I fix it?
How Can I change the name of Windows Administrator account.
What version of DirectX is compatible with Window 8? And what are the other graphic hardware accelerator (asides from direct x) best and compatible with windows 8?
Hi all,
The above error can occur for two reasons,
First one,
Windows Update” Service is stopped or not placed in Automatic.
Second one,
The service - Windows Modules Installer is not place to manual as Start-up type.
Error: 80070422 SelfUpdate Failure Software Synchronization Windows Update Client failed to detect with error 0×80070422
Hello all,
I got a problem. The Windows 8 user Preview is downloaded like a Web Installer named Windows8-ConsumerPreview-setup.exe.
But on my Pc the Web Installer collapsed while trying to check Application Compatibility. What should i do now? I need your help. Thanks.
Error: Undocumented commandline switches for Windows 8 CP
Windows 8 Consumer Preview Setup
Windows 8 Consumer Preview Setup has
stopped working
Hello
I have tried to set up Notepad++ on two PCs but got the following installer error
Mention that, I used Windows7 Ultimate 64bit on my Pc and also the Installer package. What should i do now? Please help. Thanks.
Error: SciLexer.dll installer-error
