Display :
Category: Virus & Spyware
I am running Windows Vista SP1 and Norton Internet Security 2012. I was using the 2011 version and was recently updated to 2012. After scanning, it found one issue but I noticed that everything under the computer tab in Settings is grayed out. And then it shows “Error 0x80070021”. I posted the screenshot below. What should I do next?
Error Code 0x80070021
Since yesterday we have been receiving pop-up messages on out Windows XP and Windows 7 client PCs. The error says “Fcagte.exe Application Error. The instruction at 0X7777e4b4 referenced memory at 0X00000012. The memory could not be written. Click on OK to terminate the program.” This error incurs after our recent VSE 8.8 upgrade. When clicking on the OK button on the pop-up alert, the Fcagte.exe will restart. We have tried to re-install DLP but the same error appears. How can I fix it?
My Android phone always shows ads in my notification area and this shows almost every day. Does it mean my phone is infected with a virus?
I am running WinDoctor and there is an error that says “ORUN32.exe is missing” and so I cannot access learn32.dll and pctree32.dll. What should I do?
I was downloading AVG File Server Edition 2012 Trial when I got an error "AVG 2012 Not Supported on this operating system". I am running Windows Server 2003. Is it compatible or not? What are the requirements needed?
I used AVG 2012 on my Vista PC. My problem is, I noticed that it’s always showing a “Not Active” status and also, the protection is always set to Disabled. And then I saw an error 0xC0070643. What should I do?
Hello members! My Norton Antivirus 2010 has not been working for a week on Windows 7. I was unable to do the update or analysis, and an error message popped up. When I tried to update Norton, a small window appeared, but nothing happened. I also tried the tool reboot, but again, nothing happened. Please help me resolve this issue, I have provided a screenshot of the error message below.
After updating McAfee, I encountered an error:
McSACore.exe - Application Error
The exception unknown software exception (0xc0000417) occurred in the application at location 0x00fa8d12.
It keeps on popping up and I don’t know how to get rid of it. Please help me.
I have an error with Symantec Endpoint Protection (SEP):
Application popup: SmcGui.exe - Application Error:
The exception unknown software exception (0x40000015) of the application
Occurred in 0x6b2521a8
What causes this and how to resolve this?
I encountered an error 8506,422 on Norton Internet Security 2012 when trying to perform a fresh installation on my new Windows Vista PC. I lost my internet connection since I got the error. And the only way to get the connection back is to uninstall the NIS 2012 again. How can I continue?
