Display :
Category: Virus & Spyware
Good day!
Please help me on this issue related to McAfee Security Center.
According to the error stated on the screen, the security center is not responding.
What would be the cause of this and what should I do to solve this?
Error:
McAfee Security Center is not responding
Windows is checking for a solution to the problem
By the time I try to log in into the McAfee forums, this error always appear on the screen:
Error:
An unexpected error has occurred
Please give me some idea on what causing this issue and how to deal with this kind of problem?
As part of my routine, I start up my laptop and run Cyberghost VPN. When I was about to install Kaspersky Anti-Virus 2012 on my system, an error message prompted me.
The error message says:
It is currently not possible to connect to the CyberGhost VPN network.
Check your firewall settings and make sure that you have an active
Internet connection.
Error:
Internet connection
Now, in IT industry that continuing to improve there always threats in our computer society like harmful virus.
What is the best antivirus can prevent computer virus in computer society?
Angry Bird's Android Versions are loading with viruses from the webs. How can I protect my Android Mobile affecting the VIRUS of Angry Bird, and from where can I download a safer version of Angry Bird?
I need to know how to clean up a malware-infested PC? I’ve tried using Emsisoft Emergency Kit 2.0 Beta but unsure about the procedure. Can anyone help with it?
I can't access registry files without the computer shutting down, I can't even type registry files into google and search it without shutting down.
Something is wrong with the Avira Antivirus I have installed on my computer. It is not able to update the virus database. When I click on update, it would only scan for an update and eventually would give an error that it failed to download the update. I tried to update it several times but it always gives the error.
Please help.
How can I update my version?
Hello there,
My computer just won't work the way that it used to.  The screen hangs for several minutes, and I have to keep restarting the thing.  I think there might be a virus.  I haven't dealt with viruses before.  What should I do first to fix my desktop computer?
Regards.
Fake Instagram, is this the new way of the bad guys to get through your system and access your information unauthorizedly?
