Is it safe just to quarantine a virus?or you really have to delete the quarantined virus? whats the best thing to do? What if the files infected are important?
- 229 reads
- 2 comments
Hi! I’ve been reading about CRM (Customer Relationship Management) System, it says that it keeps information of every customer to a business deals with. Does it ensure security for the customers? Is there any possibility for theft of Customer Information and Scams Attack? Please Advice.
- 223 reads
- 1 comment
What preventive measures do I need to do to make sure that my computer isn't affected by the Stoned Empire Monkey virus?
- 287 reads
- 2 comments
My computer has a Virus-Network Worm pop up, that keeps showing up on my toolbar also says Network-iVirusfp what do you do to get rid of it?
- 229 reads
- 1 comment
Is it important to use an antivirus on an android phone? If yes, what is the best Antivirus that you can recommend?
- 261 reads
- 2 comments
My pc has suddenly slowed down. I think it is because of my anti-virus. I have recently installed kasper internet security and sinice than It is working like old man. I do not what to do. Is there a way to solve this problem. I need the internet security since use the internet a lot. Kindly someone help me out of this problem.
Arnold Huang
- 245 reads
- 2 comments
Some of my windows files are growing in size upto megabytes and my computer is also running slow. Am I infected by trojan?
How to remove trojan from my pc? Shall I be using antivirus or trojan remover?
- 200 reads
- 2 comments
Home page of any antivirus site not opening in any browser while all other sites are working fine.
When the search page with antivirus key word not loading
- 405 reads
- 1 comment
I need urgent help.I just installed alcohol software on my other pc but since then my pc is restarting itself. What may be the problem? Please help me with this?
- 199 reads
- 2 comments
