Display :
Category: Virus & Spyware
Hello there,
I have this error caused by Kaspersky and it appeared when I tried to open the program after all my application started when my PC was turned ON. I can’t get rid of it and can anyone help me please to fix this ? Why I have this error and what is causing it ?
Thank you !
To continue installation you must close all application that can block access to local area connection settingS. If you are not sure which applications must be closed, reboot the computer.
Hello experts,
These windows appeared on my desktop this morning. I had to close the manually and after I ran a deep scan of my PC and no viruses were found. What this means ? Should I be worried ? I was hacked ? Please help me experts !
Thank you !
Vicrypt error! Please Restart Windows.
Vicrypt: a problem occurred, please restart windows.
I cannot open Kaspersky Security Center because of this error, it cannot connect to the Administration Center. I have checked my Internet connection and is working just fine like usually. Does anyone have any idea about this error ?
Regards experts !
Hi there,
I am the only user of my PC and I have all the administrator rights but I have this error when I want to change some settings in Avira. Can anyone tell me what could be the problem with my antivirus ? How can I get the permission to access the items ?
Thank you !
C:\program files\avira\antivir desktop\avconfig.exe
Windows cannot access the specified device, path or file. You may not have the appropriate permission to access the item.
Hi there,
During the scan of my PC with Avira antivirus this error appeared. After I clicked the OK button the program closed and I had to restart my PC to open it again. It appears every time when I want to scan my PC. Can anyone help me please to make a complete scan of my PC ? What could be the problem ?
Regards experts !
Avscan.exe – Erro de aplicacao
A excepcao unknown software exception (0xc0000409) ocorreu na aplicacao na localizacao 0x0042ff93.
Clique em OK para terminar o programa
Hi there,
This error occurs when I want to use Malwarebytes for my Windows 7. Everything on my PC is up to date and I expected that everything will work properly. Can anyone help me please to solve this error ? What is happening with my PC?
Thank you !
Malwarebytes’ Anti- Malware
An error occurred, Please report the following error code to the Malwarebytes’ Anti-Malware support team.
Error Code 724(0, 6 )
I have deactivated my Windows 7 firewall and I still have this error when I want to open Python. I just cannot get rid of this error. Is there an expert who can help me fixing this error ? Why is not working since my Firewall is not activated ?
Thanks !
Subprocess Startup Error
IDLE’s subprocess didn’t make connection. Either IDLE can’t start a subprocess or personal firewall software is blocking the connection.
IDLE Subprocess Error
Socket Error: No connection could not be made because the target machine actively refused it.
Hello experts,
I just installed Malwarebytes for PC and this error appeared when I tried to open the program. I reinstalled the program again and still. Any solution ? Can anyone tell me please why the program is not working on my PC ?
Regards !
An error occurred. Please report the following error code to the Malwarebytes’ Anti-Malware support team.
Error Code 732 (12002.0)
Hi there,
I just installed an Antimalware on my PC and this error appeared when I tried to open the program and after I pressed OK my PC rebooted. The installer was downloaded from a trusted source and is compatible with my Windows XP. How can I solve this ? Why this Antimalware is now working ?
Thank you !
MsMpEng.exe – Application Error
The instruction at ‘0x03f281d2’ referenced memory at “0xffffffff”. The memory could not be “read”
Click Ok to terminate the program
Click on CANCEL to debug the program
When I want to install this plug-in for my antivirus Avast this error appears and I can’t figure why is not working since they are compatible with each other. Can anyone help me please to fix this one ? How can I make this work ?
Thanks !
Avast information
There was an error while installing the plug-in.
