Hi everyone. I accidentally installed c cleaner full version registered, how to uninstall this c cleaner full version registered without damaging files and I need to retrieve deleted files? Thank you.
- 33 reads
- 2 comments
Hi. My Kaspersky anti virus 2010 is not working, how can I upgrade my Kaspersky anti virus 2010 18 32 to the 2013 without using any activation code? Thanks for the help.
- 66 reads
- 2 comments
Hi. I'm asking about this cookie cleaner windows open source, where could I find a cookie cleaner windows open source that will delete all my cookies in a public place like wifi? Why can they see my cookies?
- 35 reads
- 1 comment
What are the most effective ways of detecting macro viruses and is there a software for macro virus removal that is applicable for all types of Operating System. If your computer is infected by this, can it harm and corrupt the files saved on both RAM and ROM?
- 46 reads
- 1 comment
I have been in trouble with the viruses for several days. Viruses are trying to slow down my Computer and pops up annoying messages. How it can be removed in a easy way ?
- 50 reads
- 1 comment
I want to install VIPRE. But I received error 1321 while trying to install VIPRE. Please help me to solve this problem. The error message says,
” Error 1321. The installer has insufficient privileges to modify the file”
- 94 reads
- 1 comment
I use Norton 360. But I faced a problem in One Click Support. An error message is shown. Error message says,
” One click support
An error has occurred with Norton 360
Error; 8504, 101
No automatic solutions were found. Click Launch Support Web Site to continue.” while I was trying run the Run LiveUpdate item.
- 71 reads
- 1 comment
Hi! I am trying to install Norton 360 V3 and it keeps coming up with an error. Does anyone know how to resolve this problem?? The error message says:
” A problem has occurred that needs your attention:
The install file cannot be properly validated. Please try again. If you continue to receive this error message, you should run a Windows Update and then try again.
Go to Technical Support Web site”
- 82 reads
- 2 comments
A few days ago I installed antivirus in my computer but at this time when I search for antivirus it does not show. It gives me this error when I search for antivirus. Help me please.
Problem: You’ve requested the function that requires installed antivirus software.
Hi!
I was trying to install Malwarebytes software, it’s an Anti-Malware software system, but I faced an error during the process of installation.
I have just one option to click OK, and when I press the button of OK. The error message again generated with the same manner and it repeats again and again until I have to go into task manager and kill the process from there.
Please tell me about the valid URL to download the installer and tell me the solution of this error according to your knowledge and experience.
- « first
- ‹ previous
- next ›
