Hi guys,
I have a very serious problem. As every one is familiar with cloud storage service which is growing fast now a days. I have an account on "box.net" containing 150 GB data and now want to transfer it to another cloud service i.e "Google drive". I have used "mybackupbox" for this but it does not permit to choose files & folder manually. On forward i worked on s"toragemadeeasy" but problem arises when uploading whole folder. As there are more more files (approx 36,000) than folders, it will take long time to transfer files one by one, Additionally it supports only 2 GB bandwidth monthly on free account.
- 49 reads
- 1 comment
I plan on using Google Drive for storing my files and data that includes videos and PDF's where I can access it anywhere which is a big plus for me. What are the disadvantages of Google Drive in terms of security? Thanks.
Hello TechyV!
Do you know any dead card recovery softwares? I would like to see if I can still recover my SD card. There are many very important files in the memory card and I want to know If I can still recover them. The error says that I need to reformat the card but I do not want to do it because my files will be deleted. Please help me anyone. If you can give any information, it will be a big help.
Thank you so much,
Alison
- 106 reads
- 3 comments
Hi expert, I need some offsite data storage solutions for following facts. How to increase the speed and reliability of recovery, the restoration of data and How to minimize the burden on your administrative and management teams. Suggest some valuable solutions to fulfill above facts.
- 34 reads
- 1 comment
Hi Experts,
I am using Hcl ec2 technology and very happy till now. My only problem is pop saying low buffer dynamic. Someone told me this is because HCL utility HCL EC2 software, Please let me know what the exact problem is and how to fix it. Thanks
- 77 reads
- 1 comment
I have question about encrypted file storage when the cloud storage providers that there no existing storage , would it be possible to add a layer of encryption before the files are saved? I really need help. This is my first time that my storage is already full what should I do? I need to buy new storage device? Please help me.
Hi. I have many discs containing important softwares and there is a problem how to keep them save. For the safety I want to wrap bootable CD dvd with A4 paper. What is the proper way to wrap and protect them.
I often listen about bad sector.
I want to know that what the bad sectors are.
And what these bad sectors do.
Please remove my confusion.
- 50 reads
- 1 comment
I heard that we can save the space by compressing the audio song files.
If I compress the song file then what will happen.
- 40 reads
- 1 comment
Hello expert, I put some audit program files to my USB disk. When I put the USB stick into other computer the files are not shown. Please help, is the problem is on a USB stick or audit program file. All other files are shown properly.
- 54 reads
- 1 comment
- « first
- ‹ previous
- next ›
