I was struggling with this for the past few days. The problem I have is: I need to schedule backups for different times for my HDDs which are M(9GB), N(18GB), O(15GB) and P(35GB). Everything goes fine till the backup job for P drive fails and gives the following error message.
- 386 reads
- 1 comment
Some pros of the SyncBack SE 6.1.1.22 are being able to copy files that are open or locked, a file log, and filtering compression. What are other pros and cons of this product?
- 210 reads
- 1 comment
what is difference between limited rewritable and fully erasable optical disks.? an optical disk labeled limited rewritable that mean that it is fully erasable?
- 347 reads
- 2 comments
I need to make a backup of my necessary files using a removable media. I have a portable HDD. How can make back up ?
- 172 reads
- 2 comments
Why some of the removable backup media will be corrupted everytime the PC is not properly shut down?
- 157 reads
- 2 comments
I purchased one of those Sandisk flash drives and all of the programs that are supposed to come it are not all on it. Is there something I can download from the web to install on it to make it compatible?
- 203 reads
- 1 comment
My computer is not allowing me to open up the files on my removable USB storage device. As i attempt to open the folders this is the warning message that pops up on the homescreen: the filename, directory name/volume label syntax is incorrect.
The folders appear as this: d,3<3 in these form of characters, instead of the original file names that were created by the user myself.
I really need some advice to what i should do to overcome this problem, plese does anyone have any suggestions as i am very concerned that i have lost all my data. Does this mean that the usb has been contaminated with a virus?
I would appreciate the help, thank you.
Kind regards,
Shen.
- 186 reads
- 2 comments
I am having difficulty while transferring my songs to MP3 player. I generally drag and drop them intoMP3 folder and that's what I've been doing always and never had trouble with it. Now I am getting error code Ox80070052.
All Suggestions welcomed?
- 236 reads
- 1 comment
I’ve known about the software Cloudfogger 1.1.1349 that adds an extra layer of protection to cloud-based backups. I’m now stuck with download problem. What to do or where to download it from? Is there any complexity of installation after downloading it?
- 342 reads
- 1 comment
Why do usb's sometimes slow down my computer and other times Don't? .
- 246 reads
- 2 comments
