When I tried to copy network settings via USB, I got an error message “There was a problem starting wzcdlg.dll”. I am in trouble while I cannot fix this problem so any help from you would be appreciated.
RunDLL
- 19 reads
- 1 comment
Hi, experts! I have this old optima computer that does not load windows xp. I don't no what to do with this crap. Do I have to use my optima recovery disk for this before trying to install my windows xp again?
- 25 reads
- 1 comment
Good Day TechyV!
Can anyone please help me? I have a problem with the recovery boot sector of pen drive. My pen drive is not working fine and I can’t open all of my files from it. I wanted to recover the files but I’m not sure how to start? Anyone, please guide me. I am getting an error of “Unable to read boot sector”. Has anyone encountered this error? If yes, please help me and guide me. If you can provide a simple step by step instructions, it would be great. If you are using third party applications or utilities then please advise, it may also be helpful.
- 70 reads
- 1 comment
Hi. I just got an 8 GB SanDisk Cruzer 2.0 USB Pen Drive. I plug it on my PC and I get a "not formatted" error. I also check the usable space and it only has 64 MB. Why is my 8GB pen drive showing 64MB only? I'm on Windows OS 8.
- 96 reads
- 1 comment
Please help me with my problem. I cannot access the files on my 640 GB Samsung G2 portable USB drive. It says "Sector 0 error". What does this mean? I'm on a Windows XP 64 bit SP 2 system. Thanks in advance.
- 70 reads
- 2 comments
Hello! I am planning to buy an external hard drive because my PC is full of pictures and it is eating up my memory. I want something that is not so expensive but has a good performance. My friend suggests to try a Seagate brand but I want to be sure that it will worth my expense and has value for money. Can someone give me a Seagate sata3 2tb review?
- 42 reads
- 2 comments
I usually save many of my important files on a re-writable DVD. Some of my files are corrupted and I use specific software to recover files from DVD pro such as Bad Copy. But it takes too long to recover the files that it takes 24 hours in every file, is this the normal operation process on all software recovery?
- 35 reads
- 1 comment
Hello Friends!
Do you know what is the best software to clone CF cards? I have tried some free softwares but they are no good. Most have internal debugging and installation issues. I want to use the easy to use but efficient software to clone my compact flash cards. Can anyone please help me? Your advices will be a great help.
Thanks!
- 80 reads
- 1 comment
I just bought a new PC and I'd like to transfer all of my old PC's files to this new one. I'm scared that if I start transferring, some error might happen and I lost all my files. How can I create a backup disc including windows ghost?
- 42 reads
- 1 comment
Hi guys. I have a lot of mpeg and JPEG files on my 8 GB Sandisk SD memory card. I was accessing it one day and all the files were gone. So I did a scan using checkdisk and it detected bad sectors. How do I repair a bad sector in memory card?
- 65 reads
- 1 comment
- « first
- ‹ previous
- next ›
