Display :
Category: Remote Access
What's the best utility program that you can suggest for my Windows 7 and why?
Good day!
I just want some professionals to help me with this.
Whenever I work on the Remote Desktop Control, it is really slow and has a poor performance on my computer.
Is there a way to improve the speed performance of the Remote Desktop Control?
I would really appreciate your help. Thanks.
How do I access Remote desktop connection? Does it have to be more than one computer? Thank you :)
Hello
What is the best remote access/control program (that works with vista) so I can connect to my computer at home through my computer that I am using at college.
I am also going through the school's network so that means I am going through a router as well.
I have downloaded Radmin which works well on vista.
How do I get remote access to a computer over the internet?
Thank you
Command View EVA v9.4 always fails to install (no admin rights...)
I have faced the problem when I am installing Command View EVA v9.4. Installation fails every time and I always get the following error message:
Suite Installer
The current user does not have administrator privileges. Only a user with administrator privileges can run the Installation.
Thanks for the help!
I normally store data in a remote server. All the machines in our office do. But today when I go to my server and check, none of the documents were there. But when I check from my machine, I see the files. Why does this happen? need a quick solution.
I have set up a remote access for my other office. There, the machines run with Linux os. Sometimes they don't correspond to the commands I give. E.g.: exit and shut down. This has over heated the machines as well. is there any Linux software for this?
I am wondering if there is some way that I can gain access to an archived file from my home computer obtained from the Pendrive in my workplace. If there is some way please let me know. Thanks.
My file is on a network drive and every time I try to open a *.pst file I get this message: “Errors have been detected in the file z:\MyFile.pst”. Its file size is 2,856,729 KB. Then, when I attempt to change the time and date stamp on the file it still cannot open. Any ideas and suggestions?
Hi there!
I just need to know if it’s possible for me to link my two computers that are located in two different cities. I am hoping that I can so that my  information can be shared between them easily.
I hope you can give me an answer and if possible, options as well.
Thank you.
