I'm unable to boot my Meccer Classmate. It displays "Pri Master Disk: S.M.A.R.T. Status BAD, Backup and Replace
After that it displays a blue screen which reads:
Technical Information:
***STOP: 0x000000ED (0x86FDF938,0xC0000006,0x00000000,0x00000000)
PLease help me out.
- 266 reads
- 1 comment
I am using Retrospect backup software to backup my system for years. Recently I had a problem with my computer. The restore CD doesn’t worked and hence had to reinstall the entire OS and update it. Then I installed Retrospect and its updates. Later while trying to backup, I got the error 1017. I had a research and tried the available resolutions. Now I am able to complete the backup but with error 8000. Then I downloaded free backup software and finished the backup process without any errors. Now I would like to restore the Retrospect backup and on trying that I got the same 1017 error. I have goggled this error and tried the VSS fix as suggested in some forum. But I am still receiving the same issue. What should I do to get rid of this?
- 648 reads
- 3 comments
I encountered series of errors and problems with my computer so I decided to do System Restore. When I am done restoring a project file from my backup, the video clips and images are showing with no frame. During the uploading process I got a message stating that some files are missing and the procedure to locate them manually which I followed correctly.
I am able to play them outside VideoPad 2 although some of the files play only the sound part in VideoPad. I am also unable to play the preview of the project. How can I retrieve my project?
Any help will be appreciated.
- 331 reads
- 1 comment
My disk storage firmware is not reading data nor is it even physically opening the drive. I checked the tool settings, which indicated that it should be functioning well and I even hoped that deleting then re-establishing the program that ran the device will solve the issue but I was not successful. Could it be a problem with physical parts of the firmware? Can you please help me on how to make my device work?
- 238 reads
- 1 comment
I bought new HP Compaq dc7700 Convertible Minitower 3 days ago. After using it for a couple of days, for some reasons the system’s time keeps reverting even after setting it again. I’ve tried changing batteries but the problem still remains. Can someone provide me with solutions to this problem? Thanks in advance to those who can help me solve my problem.
- 672 reads
- 1 comment
I am facing problem with the photo uploading. I can upload the photos with 1600 pixel but it does not allow me to uploading with its original size. Those images are sized around 7 ½ MB and 16 Mega Pixels. The Picasa is allowing both the features. But it is not allowing its original size as it says ‘Storage is not available’ and the error code is 10. Even though it is showing error message, the images are uploaded successfully and it is viewable. But it is not allowing me to upload multiple images in a single time.
Please guide me.
Thanks in advance.
- 279 reads
- 2 comments
I am using Dell Inspiron 1720 which runs with Windows 7 and the browser is Firefox. When I am trying to add LaCie Genie Timeline external drive an error message just comes up. ‘Warning! Back up is not configured. It is not able to access the backup settings. It is to be set up a new back up’. After the message, I have to start a new back up. It is happening most of the times.
Please help me to solve the problem.
Thanks in advance.
- 310 reads
- 1 comment
I still have a lot of space on my hard drive. I checked on it so I am certain about it. After having my hard drive defragmented by using Auslogics Disk Defrag, specifically the option called Defrag and Optimize, an error in the system is telling me that there is no more space on my hard drive. I tried using Windows Explorer and it tells me the same. The error says that: "There was zero space on the drive and data could no longer be written." This means, files could not be saved or created on my default drive. I could only be able to see the free space when I restarted my computer. But I still could not save my files and I’m going to lose them when my computer is restarted. Please help me. I need to save data every day. How can I do this successfully?
- 240 reads
- 2 comments
