Display :
Did not find what you want,
Be the first to ask question on Storage
Category: Storage
Hello everyone,
How can I retrieve lost data that I had deleted accidentally? Some of the deleted documents files were so big they by-passed the recycle bin. I am clueless on how to go about this. There is information on the files that I want to use. What program can I use to recovers such data? The program should be cheap and easy to use.
Thanks a lot.
Category: Storage
I am trying to delete some data, but it does not delete. It keeps on insisting that other programs are using them even when I close all programs. What is the issue here and what can I do to stop such?
Category: Storage
For a company to control entry, keep track of attendance or restrict entry to sensitive areas, what input and output storage devices does the company need?
Thanks for the information.
Category: Storage
Hi guys,
I received an error message while viewing a PDF file with the QTO Hot fix 1. Have a look at the error message below. What does it mean? However, it stopped working throwing this error message. Have you any idea for the issue? Please help.
Thanks in advance.
QTO2012 - There was a problem displaying the page
QTO2012
Category: Storage
How to convert byte array in megabytes? Is there a software for free that allows the user to convert byte array in megabytes? I am just curious about it, I need your opinion about this topic.
Category: Storage
How can I store file on memory autoit? Give me some tutorials for me to perform this task and ideas too so that I will be able to know more about this. Thanks
Category: Storage
How is FLYGRIP Secure Device Holder? Shall I be able to use my mobile keeping attached with it or it is only to keep the mobile standing safely?
Category: Storage
Upgrading memory of Personal Computers boost its speed. Any other way to help PC's to work faster?
Category: Storage
Can anyone help me by enlisting the differences between a Shared Memory Segment and Simple Memory Segment and how they are used in Linux and Windows Operating Systems?
