Display :
Category: Software Others
I just download Internet Download Manager the other day and paid for a license. The program is blazingly fast and I am very satisfied with it except for one small point, which I hope can be changed. I do not want the programme to start download every video automatically. When I go to youtube it provides me with a link and the video does not play. Can I get help please?
I have just downloaded a huge file using internet download manager. The download when fine and arrived at 100% completion. Just as it was finishing, it read appending all parts and then it stopped. It is a really big file and it will be really difficult to download again. Can anyone help me?
Lately I have noticed when I copy file on my laptop, it goes automatically into a temporary folder. Also, I get prompted a pop-up message constantly saying that my files are ready to be burned. But the thing is, I do not have any burner installed on my laptop. I am currently running windows 7 professional?
Yesterday I was cleaning out my pc of random unused files. I went into file settings and turned on the hidden file option. Then I noticed that there were thousands of duplicate hidden files and I did not know how it got there. Is it safe to delete those files?
I have a question about the uninstalling of software in general. When you install a software it puts some files on your computer. What happens when you install this software? I know that the program is no longer operational on the PC but what happens to the files? Are residual files still present on the pc? Does it consume space? How to clean up thoroughly?
How can I use excel if greater than and less than logical operators? can anybody give me an idea how can I use these logical operators?
How can I add months to a date in excel? I am unable to add months to a date in excel. Do you have any suggestions how can I do this?
How to play sims 2 without cd. Is there a way to play it anyway, I heard something about a virtual cd but I'm not sure if you need the actual cd on hand.
Documents and Settings access denied windows 7.No other user accounts are visible so why can't I change things on my own computer? Do you have any ideas that might help me?
Does anyone know how can I convert a unix executable file image to something that I can view on my Mac? Is there any way to convert them?
