Every time when the machine starts I get the application error message. I tried to reinstall the application but could not fix this problem. Please help me how can I fix this problem. Thanks.
Inicio.exe- Unable to locate Component:
- 11 reads
Hi experts,
I purchased a new system with Windows OS and when I install Microsoft .NET Framework Version 2.0, the following error message appears: Required System Software Not Installed: Microsoft .Net frame work Version 2.0 is required to continue. I tried to reinstall this software but the same error message shows. You can see the image below.
There is an error message appearing in the Dual Core Center and it seemed that this is not functioning well.
I am completely hopeless with this matter. Kindly elaborate on this.
Dual Core Center
- 30 reads
- 1 comment
I am finding a hard time installing the Adobe Reader 9.3 as I am slapped with an error message which is shown below:
Adobe reader 9.3 Installer Information
Error 1606. Could not access network location 0\,
- 19 reads
- 1 comment
I got this error as well when I try to exit untorrent:
µTorrent
Unable to save the resume file. Some data may be lost.
Another program might have the file open, or the disk is full. Please correct this and click Retry. If you press Cancel, the resume file will not be saved.
In a short story, I need to fix the windows installer but suddenly an error shown underneath appears in my personal computer.
Initialization error.
This program requires at least Windows 2000 with SPTD 1.21 or higher.
Kernel debugger must be deactivated.
There was a fault while eliminating a folder or a file. The folder cannot be deleted and it is being utilized by a different program or individual. What program is using the file? Will I stop it from functioning? How? What actions should I take to solve this problem?
Error Deleting File or Folder
Cannot delete Folder: It is being used by another person or program.
- 18 reads
- 1 comment
As I attempted to unload my thumb drive the error below became visible:
Cannot delete old files: It is being used by another person or program.
Close any program that might be using the file and try again.
- 32 reads
- 1 comment
As shown in the image below, the CDex- Application was unsuccessful initializing correctly (0 × c0150002). Will I just hit Ok button to stop the application.
CDex- Application failed to initialize properly (0×c0150002). Click on OK to terminate the application.
Why this error happened? Find time to explain this immediately please.
- 24 reads
- 1 comment
After doing some series of steps a pop message just appeared and displays:
WINZIP32.EXE – No Disk
There is no disk in the drive. Please insert a disk into drive?:.
It is asking for disk which is quite awkward.
Why is it that an error like this occurs? Will you please help me solve this!
- « first
- ‹ previous
- next ›
