Hi all
I wanted to make banners so I decided to use GIMP for the image retouching and editing but unfortunately I get an error when I try to launch this application. The screenshot of the error is attached below:
Can anyone please tell me how to resolve the issue? If anyone knows about an alternative software, please tell me, I'll be really grateful.
Thanking you loads.
Regards.
- 166 reads
- 2 comments
Hi fellows,
I was trying to install advanced systemcare v4.1.0 the other day but when I entered the license key, it ended up in an error. The screenshot of the error is as follows:
Now can anyone please guide me what should I do to get rid of this error? I have searched a lot for the solution but couldn’t find an authentic answer.
Looking forward to your replies
Kindest regards
- 216 reads
- 2 comments
Hello
I am experiencing a problem with logos bible software 4. When I try to access a directory using this software, I get an error and I cannot install the update. The screenshot of the error is attached below:
Can anyone please help me remove this error? I am really worried. Any help in this regard will be highly appreciated.
Kindest regards
- 132 reads
- 2 comments
Hello
Yesterday I tried to export a sketchup file to kerkythea with a plug in but the export was not successful. It ended up in an error and the file could not be supported. The screenshot of the error is as follows:
The error says,
The file path and/or the file name contain non-Latin characters. Please save in a different folder.
I am working on a solution to this issue.
- 275 reads
- 3 comments
Hi
Yesterday I tried to add a reference of a normal class library in a Silverlight client application using a sample PCL but in trying to do so, it gave me an error. The screenshot of the error is as follows:
The error says:
You can only add project references to other Silverlight projects in the solution.
Does anybody have any idea how to get rid of this error? I'll be really thankful to you for your help.
Waiting for your comments
Regards
- 136 reads
- 1 comment
I installed Fedora 14 x64 on my OS and updated my OS. Then I installed VMware-Player. All the installation systems were performed successfully. However, when I tried to run VMware-Player I received an error message. Have a look at the error message below. It is showing that it is unable to build Kernel Module. How can I get a remedy of this problem?
Please help.
Unable to build Kernel Module.
See log file /tmp/vmware-root/setup-7357.log for details
- 130 reads
- 1 comment
The problem is with my archive manager. While uploading a file I received an error message as under. It is indicating that it cannot open .rar file. I tried several ways to make it ok but failed. If you have any idea regarding the problem, please help.
Thanks in advance.
Could not open “Examples.rar”
Archive type not supported.
- 146 reads
- 3 comments
Hi guys,
I downloaded several files in 7-Zip files. While opening those files I received an error message frequently. The screenshot of the error message is as under. Operating system of my machine is Windows 7 Home Premium. Have you any idea for the error? Please help.
Thanks in advance.
7-Zip: Diagnostic messages
# Message
0 Can not open file ‘C:\Users\Falt\Desktop\New Folder\03a_oldmombasa.map.diz’ as archive
- 261 reads
- 2 comments
Hi Experts,
While extracting a file through WinRAR I received an error message. It stopped working throwing a warning message i.e. no archives found, as it is unknown to the application. If you have any idea for the warning, please help.
Thanks in advance.
WinRAR: Diagnostic messages
Warning
No archives found
- 355 reads
- 2 comments
Hi guys,
While sharing a file with WinZip I received an error message. Have a look at the message below. What does it mean? I searched several sites to get a remedy of this issue but no result. Please help me to solve the problem.
WinZip
Multiple files were droppec, and one or more is an archive.
Add files to archive?
- 136 reads
- 2 comments
