Display :
Category: Software Others
I cannot open my QTO projects though I could open them before. I’m getting the error message shown in the screenshot. I went for reinstallation of QTO even; but could not find the solution yet. Can anyone help me please?
QTO 2012
There was a problem displaying the page.
I use Open Office for a long time and the application works fine. However when I try to have installation of an extension, an error message appears.  The message says that Java implementation loader could not be created in extension manager.  Here below is the screenshot of the error message.
Could anyone help me to solve this error please?
Thanks in advance.
Extension manager
Could not create Java implementation loader.
When I try to download Face of Mankind, an error message appears and it says that it fails to download file.  Please find the screenshot of the error message for your reference.
Does any expert know the reason for failure and how to solve this error please?  I can’t wait to play this RPG and any suggestion is welcome.  See you in FOM.
Thank you very much.
FOM
Downloading file failed
Hi There,
When I try to install Dolphin in my desktop which is running on Microsoft Windows XP, an error message appears and says ‘error processing Exec field in.’  Please find the below screenshot for your reference.
Could anyone help me to resolve this error please?
Sorry – Dolphin
Error processing Exec field in
When I try to upgrade the Karmic, an error message appears. The message says that ‘libuuid1’ package is not working while the upgrade might continue. Please find the screenshot of the error message below for your reference.
The error message also suggests that a bug report shall be submitted.  Could anyone try to fix the bug please?
Thank you.
Karmic
The upgrade will continue but the ‘libuuid1’ package may not be in a working state. Please consider submitting a bug report about it.
I am getting this error message. Please help me to resolve this problem, thanks
Sever Error 1 Occurred
Problem: Problem with the blog server.
I am facing a problem during the installation of Eesti ID Kaar DI. While trying to install an error occurs which you can see at below and help me please. How can I fix it?
Could not open key
Problem: Could not open key: HKEY_CURRENT_USER\Software\Microsoft\Internet\Explorer\Approved Extensions.
I am trying to install iwork 08 on my virtual machine but I am not able to install it because it gives me an error message which you can see at below attached image
Problem: Install Failed. Unable to install
Problem: Install Failed. Unable to install.
Recently I upgraded with Netscaler software release 9.3.48.6 Classic build. I received an error during loading the files and the error message is this “The AppFlow feature is available only on Citrix NetScaler nCore.”
AppFlow feature is available only Critic Netsocier nCore
Problem: The AppFlow feature is available only Critic Netsocier nCore.
When I search the folder from Einen Netzwerkort Hinzufugen. I received an error message:
Problem: Der eingegebene Ordner IST unguiting. Wahlen Sie einen anderen Ordner.
