Display :
Category: Software Others
The problem is with my MSI Afterburner. I have been using it for long. I received an error message yesterday as under. After throwing the error message, it stopped almost all the activities. I have no idea for the error message. If you have any idea for the issue, please help.
Thanks in advance.
MSI Afterburner 2.2.2 Setup
Error opening file for writing:
C:\Program Files (x86)\MSI Afterburner\Bundle\OSDServer\RTSSHooks.dll
Click Abort to stop the installation, Retry to try again, or Ignore to skip this file.
Hi Experts,
My MSI Afterburner has encountered a serious problem. It has stopped running threw the error message asunder. I uninstalled MSI and installed it again. However, the same error message remains unchanged. If you have any idea for the issue, please help.
Thanks in advance.
MSI Afterburner
Some of MSI Afterburner components are expired, missing or corrupted!
Hi guys,
Have a look at the error message below regarding EVGA Precision X error. I received the error message while closing my EVGA Precision v3.0.3. The same error message is also applicable for the moment making any changes in it. How can I get a remedy of this issue?
Please help.
EVGA Precision X
RTTSH.dll::DeleteTask failed with error code -3!
Hi guys,
The problem is with my benchmark tool 3DMark. I received an error message in SLI on my computer running with Windows Vista 64-bit Service Pack 1, intel Q9450 processor and 512 MB of 8800GTS. Have a look at the screenshot below. Have you any idea for the problem?
Please help.
IMPORTANT INFORMATION
Oops!3DMark has unfortunately encountered an unexpected problem during the benchmark run and was forced to abort the test. This is what 3DMark wants to say the exact nature of the problem:
Std::exception
ID3D10Device::CreatePixelShader failed: An invalid parameters was passed to the returning function (E_INVALIDARG)
The problem is with my ATI Radeon PowerColor HD4830. I collected it for using CrossFireX within the card. However, my PC is showing an error message. Have a look at the error message below. What does it mean? Is it a compatibility issue? How can I get a remedy of this issue?
Please help.
Thanks in advance.
HGWC
File is changed : W[2007]L[0]
Crossfire.exe
The problem is with Nvidia graphics driver. While playing a game it has stopped working. Sometimes it is showing the black screen and sometimes for a few moments playing the game. Then it stops throwing the error message as under. Have you any idea for the issue?
Current configuration of my machine is i7 860, 2.8 GHZ with GTX 560 Ti 1 GB RAMS.
Please help.
Guild Wars 2
Guild Wars 2 has encountered an unrecoverable graphics driver error and must terminate.
Click on the URL below to open a web page with more information.
http://support.guildwars2.com
Hi Experts,
My NVIDIA OpenGL driver detected a problem with the display driver and failed to continue throwing an error message. The screenshot of the error message is as under. My machine is running with main board, Intel Core i7-2700k processor with Win 7 Ultimate Service Pack 1 64-bit.
Please help.
The NVIDIA OpenGL driver detected a problem with the display driver and is unable to continue. The application must close.
Error code;3
Would you like to visit http://www.nvidia.com/page/support.htmlfor help?
I installed ATI Radeon HD 4600 on my machine running with Windows 7 64-bit operating system. After that, I received an error message (application error). I clicked on OK but no permanent solution. How can I get a remedy of this issue?
Please help.
dustforce.exe - Application Error
The application was unable to start correctly (0x000007b). Click OK to close the application.
While running AMD Catalyst Suite Manager I received an error message. It has failed to download due to incompatible hardware/software on my computer and my graphics driver is not supported. Have a look at the screenshot below.
Have you any idea for the issue? Please help.
Thanks in advance.
AMD Catalyst Mobility cannot be downloaded due to incompatible hardware/software on your computer.
The version of your graphics adapter is not supported.
Please contact your notebook manufacturer for a graphics driver update.
Hi Experts,
While installing Element 3D for After Effect I received an unexpected error message. Look at the screenshot below. It has simply stopped installation throwing the error message. I searched several sites to get a remedy but no result. Have you any idea for the issue?
Please help.
Thanks in advance.
Unexpected error
An error occurred while installing Element. Please contact support.
