As I attempted to unload my thumb drive the error below became visible:
Error Deleting File or Folder
Cannot delete old files: It is being used by another person or program.
Close any program that might be using the file and try again.
- 61 reads
- 2 comments
As shown in the image below, the CDex- Application was unsuccessful initializing correctly (0 × c0150002). Will I just hit Ok button to stop the application.
CDex- Application failed to initialize properly (0×c0150002). Click on OK to terminate the application.
Why this error happened? Find time to explain this immediately please.
After doing some series of steps a pop message just appeared and displays:
WINZIP32.EXE – No Disk
There is no disk in the drive. Please insert a disk into drive?:.
It is asking for disk which is quite awkward.
Why is it that an error like this occurs? Will you please help me solve this!
I attempted to squeeze a file to save disk space but unfortunately an error message occurs.
Compressed (zipped) Folders Error
There is not enough space on the drive to perform this operation.
- 26 reads
- 1 comment
I have a problem using my ATIWinflash while flashing bios using ATIFlash, the following message appeared: “No valid adapter could be found! Video BIOS not updated!” Is there any solution for this error?
ATIWinflash
I have a recurring error code with Poker Tracker. Whenever I do a query, I am getting a message that says: “A database error has occurred.” Specifically it says, “ERROR: value too long for type character varying.” Does this have something to do with the text that I’ve inputted? Or is it just a bug? Please respond as soon as you can.
Cheers!
Database error
- 38 reads
- 1 comment
Good day,
I badly need help concerning an error code. Whenever I attempt to login, I receive this “Log notification: fatal” in which I have no idea what it means. I am to my wits end because it tells me that I might want to save my logfiles! Anyone is welcome to give their thoughts on this.
Thank you very much.
- 101 reads
- 2 comments
Hi there,
I have installed Holdem Manager, and when I ran the application it tells me this: “Please note that all new versions of Holdem Manager require the Microsoft.NET Framework Version 3.5 service Pack 1.” Then there is a link that will lead me to download the Microsoft.NET Framework, but then again it would give me an error thus I still couldn’t install it.
So the game manager wouldn’t let me run the application because of an update, but the update seems to be faulty as well. Is there any workaround on this?
I am in your debt if you could help me with this
I am having a problem concerning a “.dll” installation to the GAC. The error message tells me that I do not have administrative access or administrative credentials for the task.In other words it tells me that I am not the administrator. Any ideas why this is happening?
Thank you in advance.
Error
How can I install My Labels Premium Software on my Windows XP laptop? What is the minimum system requirements and how does it differ from any other label software? Is this software easy to use and is it easy to customized from it?
- 126 reads
- 2 comments
