Display :
Category: Software Others
I have a hotspot here at home and i wanted to block out some domains such that if they are detected, a message is sent to the respective user notifying them that the domain is blocked. Do you know of any software or setting that i can use to achieve this goal
I have a project that involves using the eingen faces for face recognition and im not really satisfied with the results when i do a face recognition using the algorithm and i was wondering if there was a better algorithm apart from the two algorithms or a better implementation using fisher face would do
What is an Application programming Interface? Name some important APIs in the context of software applications. What are some qualities of a well designed API? What are some defects of a poorly designed API? What are the considerations to be kept in mind while building a secure API? Why does a company release its proprietary API to the public?
Big data is one of the upcoming software trends predicted for the coming years .With reference to this please explain what is Big data? On what factors is it characterized? How are major enterprises using Big data to improve their decision making capabilities? In comparison, what is small data? Small data is important for which segment of customers?
I am using mHotspot version-8 in my Sony Laptop to use it as hotspot. I started the mHotspot and my wireless network and then trying to connect my smartphone with it but it is showing “obtaining ip address” only and not getting connected to internet at all. I am not able to share internet at all. Please tell some way to resolve this issue.
I am using WinRAR in my laptop for extracting file. I have downloaded an album from songs.pk last week. I have extracted songs from the file easily but now when I am trying to extract it is showing error message “Can’t execute filename...”. Please suggest any method to fix this issue if possible.
I'm sure there's more than likely a thread for this, but I've googled all night and nothing helped me. I'm at a loss here. I'm running windows 7 32bit,whenever I try to add a virtual drive it starts off normal,but then says "unable to add virtual drive" WindowsFixIt or whatever it was called,did not fix it. Any suggestions would be lovely,I used to run Daemon Tools lite on windows XP smoothly before I reformatted. I don't want to use a different program as Daemon Tools is what I know . help!
Every time I select to open an .iso file with Daemon Tools, I get an error stating "Windows Can Not Find F:\ Make Sure You Typed The Name Correctly, And Try Again." I have used Daemon Tools on other file types with no issues & had done Iso files in the past with no problems as well. Whats going on here? Please Help, Thanks.
I downloaded an ebook of Automata to prepare for my internals. It is a scanned copy of original book. Right now, I am facing a very big problem as I can't search for a keyword inside it. Can anyone tell me, how I can search for keywords in a scanned pdf? Is there any way to convert it in editable form? I don't want to face this problem in my externals. Please help.
How to Installation and configuration Google Shopping Feed What are the detailed steps to follow to install and configure Google Shopping feed? My name is Trish Kusi Appiah and a second year Sociology student of Christ Apostolic University in one of the West African Countries. I would like to know the simplest but detailed processes involved in performing the above mentioned task. Thank you.
