Display :
Category: Software Others
Hello! I have an old Xbox 360 and it does not have an internet connection with it. I have some video files and I want to play them on my Xbox 360. What format would be required to play them on my console? What software should be used to convert them to a playable format? I cannot go for an Xbox update since I do not have an internet connection with this console.
Hello! Is there any program which can convert all my MKV movie files to a format which I can burn on a disk like the AVI format or the MP4 format. I tried to use a few programs but that ended up not working. I have heard that there is actually a program with a name starting like convert......something. It worked before. Anyone knows the correct program? Thanks in advance!
Hello! As we all know there are different kind of soft wares available in market for different purposes, I want to know real life examples of the following types of soft wares:
1) Names of Application Soft wares
2) Names of Embedded Soft wares
3) Names of Artificial Intelligence Soft wares
4) Names of Product line Soft wares
Hello! I am a student of bachelors in mathematics. I just want to know if there are any good soft wares which can be download as an aid in calculus. I am looking for something which can generate a result of an expression, integration and derivation both and also highlight the important steps which are used to solve a particular problem.
Hi! I am supposed to write a one page assignment related to CPM Analysis. The only thing that I know so far about CPM in the development of a software is that it stands for Critical Path Method. I want to know what it means, what it does, what Early Start, Early Finish, Late Start, Late Finish, Total Slack and Free Slack mean in CPM?
