Display :
Category: Software Others
Is the program asrock fast lan utility any good for lowering the latency for games and online gaming? Will it slow down the game  or hinder my gaming experience in any way?
I would like to know if you can import dwg files to smart draw and if it supports DXF and DWF as well as DWG? What else does it support that is associated with CAD software?
I have a NTFS drive running but r studio network edition does not recognize it. I get the error message - "Error in setwd("R:/") : cannot change working directory". Windows file explorer can access the drive with no problem.
I need an easy ebook cover generator that is fairly simple to use and is free. I have performed searches previously but unfortunately all my results produced where just trail versions or where to complicated for me to use.
I have the free version of pinterest clone v2 which utilizes a single mod. I was wondering if getting the paid version which uses a multi user mod would be worth investing the money in?
When I run dropbox with remote desktop manager enterprise it runs perfectly fine but if it goes into hibernate it will freeze for some reason. Would reinstalling the application fix the problem?
What is a simple ticket tracking application that has some type of in built customer satisfaction rating system and can also manage a high volume of customer requests. If the application is worth it I am willing to pay for it.
I have to get the output for mysql show create table and write it to one file for each table that I have. How would I do this? Im guessing  stored procedures would help in some way?
I'd like to know how to use Wysiwyg to add a personal font. Can someone provide steps to do so? Id like it to be added to both the ​wysiwyg editor and toolbar if it's possible.
When I try to create a new connection with the putty connect manager ext it gives me an error. When I enter the shell login and password, it freezes and stops responding. Is there any way I can fix this? I've tried reinstalling the program with no luck.
