I have a recurring error code with Poker Tracker. Whenever I do a query, I am getting a message that says: “A database error has occurred.” Specifically it says, “ERROR: value too long for type character varying.” Does this have something to do with the text that I’ve inputted? Or is it just a bug? Please respond as soon as you can.
Cheers!
Database error
- 17 reads
- 1 comment
Good day,
I badly need help concerning an error code. Whenever I attempt to login, I receive this “Log notification: fatal” in which I have no idea what it means. I am to my wits end because it tells me that I might want to save my logfiles! Anyone is welcome to give their thoughts on this.
Thank you very much.
- 20 reads
Hi there,
I have installed Holdem Manager, and when I ran the application it tells me this: “Please note that all new versions of Holdem Manager require the Microsoft.NET Framework Version 3.5 service Pack 1.” Then there is a link that will lead me to download the Microsoft.NET Framework, but then again it would give me an error thus I still couldn’t install it.
So the game manager wouldn’t let me run the application because of an update, but the update seems to be faulty as well. Is there any workaround on this?
I am in your debt if you could help me with this
- 17 reads
I am having a problem concerning a “.dll” installation to the GAC. The error message tells me that I do not have administrative access or administrative credentials for the task.In other words it tells me that I am not the administrator. Any ideas why this is happening?
Thank you in advance.
Error
Can you please help me how to install my labels premium software in my windows xp laptop? What are the system requirements for this software? Compared to other label software, how is this different? Is this easy to configure and how about the way it will be customized? Is this any good? Honest opinion matters.
- 46 reads
- 2 comments
Hi. I'm working on my Nintendo 3ds installing adobe flash, how can I install an adobe flash into Nintendo 3d? Why is that there is no direct access to download this software? Thanks.
- 65 reads
- 3 comments
Hi. If I will handle this CSS market template, what may be the most common problems or issues with designing a CSS market template? Or in designing an html template?
- 42 reads
- 1 comment
Hi. What is the cause of the errors with the use scriptella in android? How to insert column and rows based on my selected topic? Why isn't working? Thanks for the help.
Hi. I need a MIDI converting studio on my mobile phone. How can I convert my videos from my mobile phone into this MIDI converter studio? Please explain how. Thanks a lot.
- 38 reads
- 1 comment
- « first
- ‹ previous
- next ›
