Display :
Category: Software Others
Hi there,
Every time I run Paint Shop Pro this error with plug-in missing appears. I did not install any plug-in and it worked just fine until now. I have this error even after I reinstalled the Paint Shop. Can someone help me fixing this error message? Why I can’t get rid of this error?
Thank you!
Paint Shop Pro Photo
Unable to load the requested plug-in filter. The plug-in may not be installed properly or may be missing files. (Plugin: autint10.8bf)
OK
Hi there,
For two days I have this error message and I don’t know how to fix it. It appears every time my PC logs on. I don’t remember installing\uninstalling anything lately so is a little bit weird for me to have this error. Does anyone know what is happening with my PC and how can I fix this error?
Thanks!
FineObjects
Cannot load unicows.dll. Press Cancel to terminate application.
OK Cancel
Hello there,
After I installed Themida on my PC I got this error when I want to run it. I reinstalled the software again but it seems like doesn’t want to work. I don’t know how to solve it so please can anyone help me to fix this? Why I have this error?
Thanks!
Themida
Cannot find ‘X3DAudio1_6.dll. Please re-instaII this application
OK
Hi there,
For the first time I tried to install iTunes but I have failed by getting this error messages. Now I reinstalled the program at least 5 times but always the same error. Now I give up and please is there anyone who can help me to fix this and give me the standard steps to install iTunes?
Thank you!
iTunes was not installed correctly. Please reinstall iTunes. Error 7 (Windows error 126)
 iTunesHelper was not installed correctly. Please reinstall iTunes.
Error7
OK
Hi there,
This error appeared on my desktop after the installation of TeamViewer was done. As the error says it seems like is an error about the package installer. The first install was made from the official TeamViewer servers and also I tried to install from different servers and all have the same result. Please help me to install TeamViewer. Why I have this package error?
Thanks !
An error occurred
The following details are provided:
E: The package teamviewer needs to be reinstalled, but I can’t find an archive for it.
E: Internal error opening cache (1). Please report.
I am unable to work with TeamViewer at my job because this LANDesk Software Monitoring blocked the program. I really need the TeamViewer to work because I have to solve some problems so can anyone help me to pass this monitoring software? What should I do? Is there any other remote control software that can help me?
Thanks experts!
Administrative policy does not allow usage of the following application. Access to it has been blocked:
C:\Users\tma0258\Desktop\TeamViewer
Hi experts,
I have this weird error about Legitimation Confirmation and it appears every time, and I have to click Trustworthy so I can continue work with. Is there any way to change the settings? How can I change this so it won’t appear every time?
Thank you!
Please be careful with unsolicited calls.
Do you know the person you interact with at the moment? This technician is using a free trial version of TeamViewer.
After I installed TeamViewer this error appears every time I want to open the program.  This error appears even when I try to open the program from this address: C:\Program Files(x86)\TeamViewer\Version8\TeamViewer.exe. I don’t know how can this be fixed so can anyone please help me with this one? What is wrong? I have installed the program following the standard steps…
Thank you!
Hello there,
After I installed TeamViewer program and tried to open it this error appeared on my desktop. If click the Skip button a Don’t Send Error appears and if I click the Cancel button everything is closing. I have this error to all versions of TeamViewer. Can anyone help me to fix this error? What the TeamViewer program is not working on my PC?
Thanks!
Error
There was an error on the sever for the file “C:\eula.1028.txt”
Error: The file system reported an error.
Additional information: (5) Access is denied.
Hi experts,
Today I was trying to install TeamViewer on my laptop with Ubuntu OS but I got this dependency error. Also I tried to install them but no success. I contacted many Ubuntu forums and no one came up with a solution that work. Can anyone in here help me to fix this error? What is this dependency error?
Thanks!
Dependency is not satisfiable: libc6-i386 (>=2.4)
