I have saved mp3 files using the Mixxx audio tool in Linux saved on my USB. My computer crashed and have a new one that runs Windows. I am wondering if installing cygwin audio tools can help me play the files on my Windows PC since they are originally from Linux or do I have to install another software to do that.
- 33 reads
- 1 comment
Funny windows message anyone? This is supposed to replace user but retain files of previous user and make those files accessible by the new user. Now what happens is that those files are now inaccessible to the new user. How do we take those files and make it ours?
Error
User error – Replace user
- 181 reads
- 1 comment
Dear friends,
- 225 reads
- 2 comments
Hi there,
I downloaded and installed Portable Ubuntu on my system. I was able to extract the file to my desired destination. However it is currently producing a fatal error which I am unable to interpret. I can still use Ubuntu but there is no graphical interface
- 828 reads
- 2 comments
Hi Experts,
I have two computers with almost identical configuration,both running Windows Vista Ultimate. I have installed Android ndk and have set the same configuration in both the systems. On one system,I get the error 127 while building my project with ndk-build. However the other system works absolutely fine. When I try to open arm-eabi-gcc.exe manually, I get the following error
- 312 reads
- 1 comment
Hi Guys,
An application compiled by myself in C and Win32 works to perfection when used with netbeans IDE.It does not shows any abberations whatsoever.However all my attempts to launch the application on Windows 7 fails miserably.
- 953 reads
- 1 comment
I'm developing an application using Eclipse CDT with Cygwin. Sequence of steps that I've followed is as below:
- Installed Eclipse CDT
- Installed Cygwin with gcc and g++
- Generated and added gdb at c:\cygwin\bin to PATH variable
Using the above steps I've successfully created a sample Hello World Application, which has been compiled satisfactorily. I've to set the execution configuration manually, but when it comes to debugging, application crashes with the following error:
- 338 reads
- 1 comment
- « first
- ‹ previous
- next ›
