Display :
Category: Visual basic
Dear Experts
I want to create a webpage in VB2005 which is when opened in a browser in Windows it should scroll down automatically till the bottom of the page. Can anyone give gecko vb2005 example for similar page?
Hi guys,
I am interested in making Opera Browser Control. Can you suggest sites that can teach me how to Parse Opera Browser vb6? Thanks
Hi everyone, I have inventory system using VB 2008. Can anyone suggest what storage should I use? The specification of users is limited for now but eventually might grow.
Thanks in advance guys!
Hi TechyV users!
Is there an available scripting reader vb tool for download? I really need it. If not, can some one help me how?
Kelly Abbrahamson
The error I am getting is-2147024809 (80070057). The message is that 'there was a problem in a method of this object property range:
Run time error’-2147024809 (80070057)
Microsoft Visual Basic
Run time error’-2147024809 (80070057)’:
There was a problem in a property/method of this range object.
How can I correct this error? Can it give me any details to complete this easily?
Hi, I have some important MS word files. I need them to encrypt in visual basic. So, can you please guide me how to encrypt a word in VB?
I need few design form in VB6 for entering student details. I just need images of the form, for me to refer to create a master form to enter the details of Students.
Hi programmers,
I am newbie in Visual basic. I found some sms sending software on the internet, but they are too much costly. So I decided to make a VB code to send sms from my desktop. Can someone provide me vb code for send sms to mobile? The program should be simple and easy to understand. I hope any VB expert will give me the code.
Regards
Hi guys, I need help with my isa server export file. I was using vbscript to configure, it, but after I have saved the file. My computer says that its corrupted. Can you help me with one. Thanks
Hi, I am fresh to Visual Basic, Please get me an example Scoreboard using Visual Basic that will input the Name and Score and will display the Name in an order based on the score, Please help me to find a sample that match the mentioned scoreboard for quiz Visual Basic.
