Display :
Category: Visual basic
Hi!
I would like to ask for your proper guidance. Can you show me how to declare array? What is array by the way? How to implement it in a simple program? What is the meaning and use of index in array? Can you show me how to create a simple program that will utilize the function of array? What are the objects we need to include in the form? Can you explain to me the syntaxes or commands that are included in the program?
Hello!
I would like to learn how to call sub-procedure in Visual Basic? What is the use of “Call” keyword and what is the main purpose of this keyword? Can you help me create a program that will call sub procedure? How can I implement this in my program? Can you show me how to do this? Can you explain the syntaxes that we need to use for this program? What are the objects that we need to include in this program? Please provide me guidance. Thank you!
Hi!
I would like to know more about Visual Basic. What are the two types of procedures in this language? Can you show me how to create function using general declaration? What are the uses of Sub? Sub-name? What are arguments or parameters? How to pass arguments in sub-procedures and functions? What do you mean by return value? What is the uses of Private and Public for this? Can you show me how to implement the sub-procedures?
Hello!
I want to know what are the different control flow structure. Is there any sub categories for each? What are the different operators that I can use and what are the description? Can you show me how to implement the control flow structure? How to properly declare it to my programs? What are the other controls I can use to make it work properly and interactive? Please provide me explanation if you have to show declarations/syntaxes for this. Thank you and have a nice day!
I want to go further with Visual Basic. What is operator in Visual basic? What are the arithmetic operators I can use in my programs? What is the meaning of “Order of Evaluation?” What do you mean by MOD? What is the use of this operator? Can you provide me also the descriptions of the arithmetic operators that I can use in my programs? Can you show me how to implement this operators and what are the proper uses of it?
Please help me with this.
Hello!
I would like to know what is/are variables. How to declare it in Visual Basic 2015? Can you show me a sample or way how to declare the variables? What is dim? Why do we need to declare local variables and global variables? What is/are differences between local variable and global variables? What are the purpose of it? How useful is it in computer programming? Can you give me ways on declaring different data types using variable declaration?
Hi!
I would like to know what are the data types that I can use in Visual Basic 2015? What is “Long” and “Single”? What are the ranges of its value? Can a string contain numbers and characters? What about integer? Can it contain both number and character also? What is double? What are the ranges of double type? What does it represents? What is Boolean type? What values we can store with this data type? How is it implemented? Can you help me with this?
Hi!
I would like to know more about MsgBox functions in VB2015. Can you please describe and enumerate the named literal for MsgBox buttons that I can use? What are the values I can use and describe it to me fairly? What are the message box icons I can use to notify the program user about the actions requested? Can you provide me a sample message box implementation and explain to me how it works? Why do we have to use the “+” sign every time in programming?
Hello!
I want to learn how to use message box in VB 2015. What is the use of prompt? What is the proper way to use title? Can you show me example and how to implement it? Please explain it to me also? What is xpos and ypos arguments? What is the use of helpfile and context arguments in a message box? Can you tell me what are the controls I need to use in creating a program with MsgBox? What are the properties I need to set? How is it implemented? Thank you!
Hi!
I want to know what is the use of functions? What are the different syntaxes that I can use for the functions? Can you provide me description for each function? What is the use of input box? Can you show me the declaration using an input box? What do you mean by CSng? What is the use of it? What is the meaning also of LCase? What is the use of it in VB program? Why do we always have to use “Val” in declarations or syntaxes?
