Hello fellow Techyv members. How do I retrieve IP from DHCP via VBS? I want to install a software on a PC in my workstation. I need a code or script to get the correct IP address for that particular system. Any help would be much appreciated. Thanks.
- 32 reads
- 1 comment
Hi guys,
I am looking into writing a script on vbscript to convert mac fonts to pc but the script that I came up with seems not to be working. What I am looking for is someone to provide me with guidelines on how I can create such a working script or to provide me with the ready script.
If anyone can help me on this please reply to this post.
- 23 reads
- 1 comment
Hi Techyv members, please tell me how to save attach EML in Vb6 effectively. What are the steps needed for this kind of attachment? Please show me a step by step process for this. Also, please include a few pointers about the issues to be encountered if there is any.
- 41 reads
- 1 comment
I would like to know the basic control and usage of Visual Basic for Applications (VBA) in MS Word. The main purpose for me is to create small word conversion tools using VBA. Please do the needful for providing the tutorial based on that, so that I can use it. Please help.
- 47 reads
- 1 comment
Good Day Experts!
Do you know how to clean registry with VB6 applications? Is there really an application in VB which can clean the registry? Can anyone please help me? What are the things that I need to consider before cleaning the registry? Can you provide a sample code which can clean the registry by removing all the VB6 DLL files? If you have an existing sample application, then please share with us. If you are using third party softwares, do you know where to find a free application? It would be very helpful if you can share your expertise and knowledge.
Thank you for sharing.
- 125 reads
- 2 comments
Hello Techyv Friends,
I would like to create a customized Stop Watch using VBA. Will anyone be able to provide stopwatch VBA access coding, which will a form having start, stop & reset buttons. Please do the needful for helping me by providing the same.
Thanks & Regards,
Anna Weiss
- 52 reads
- 1 comment
How do I fix the print command button on my common vb control box? Somebody set up this dialog box for
me and I didn’t know why the print button start to get an error message when I clicked it? Do you have any idea how to resolve this? I have no clue.
Hi everyone, I hope everything is great. Please give me a quick overview of the vb bpm counter method. How may I use this? What are the main functions for vb bpm counter ? I would appreciate it if you will give me a guide on how to effectively use this in the future. I'm looking forward for your response.
Hi there everyone, Kurt here. I have a project to be written in C language which I really am not familiar with, so I decided to write it in vb language and just convert it to the required language. Now the question is, is there an available vb converter to c which I could use to save time dealing with another new language? I really hope there is. Thank you guys in advance.
- 36 reads
- 2 comments
- « first
- ‹ previous
- next ›
