I want to record voice in visual studio 2008. How can I create code for microphone voice recording in it? Please, write the code successively for me.
Thanks
- 178 reads
- 1 comment
Hello techyv,
How to connect vba access 2010? I would like to connect my visual basic 6 calculator system in Microsoft Access 2010 database. I need a database that will hold all the possible data to be entered and save by the system user. Can you give me a step by step process on how to connect it properly? This is for my office database.
Expecting some help from you guys. Thank you.
- 159 reads
- 1 comment
All about sql database restore in vb6. Is it possible for this visual basic 6 programming language to restore sql database files or data? There are some instances that we have to open a data to another application for some important reason. Share with me your idea regarding this matter. I need to study sql database and vb6 for our programming team.
Waiting for your support, thank you.
- 87 reads
- 1 comment
What is the best vbscript style in making enrollment system? I don’t have any idea about visual basic classic and visual basic scripting and coding. Would you mind If I ask some help about any tutorial that you know? Anything that will possibly help me make a simple vb enrollment system.
- 101 reads
- 1 comment
I need to create a log on script with vbs. But I don't know how to do it. As a beginner, how can I start? Please, tell me everything as easily as possible as I addressed myself as a beginner in the field.
Thanks
- 114 reads
- 2 comments
I want to develop a small application in vb6. The application in vb6 will receive and send bulk SMS. I am using Micromax MMX 353G modem. My problem is that the normal AT commands are not working with this modem. I need someone to help me with at commands vb6 to receive SMS and also send in bulk?
- 230 reads
- 2 comments
I want to develop a VB multiple camera program that can process and verify the identity of a person from different angles using multiple camera. I need suggestions on the possible cost-effective camera brands and models that I could use to interface with the program.
- 143 reads
- 1 comment
What are the outlined processes in using vb net web query interaction to retrieve data from an Access database after a subsequent download of the web query and integration withing the database interface?
- 145 reads
- 1 comment
How do I write code to animate menu vb6 picture on my desktop application in order to improve the appeal of the desktop app and enhance the user experience of the potential users?
- 203 reads
- 4 comments
How can I lock button in visual basic? I have a couple of buttons and there are some buttons that I would like to lock or disable after pressing it. How can I do that? I need an idea on using visual basic lock key. Can you tell me step by step tutorial? Thank you so much.
- 129 reads
- 2 comments
