Hi there! I just wanted to know if it is possible to connect it on COM. I am currently using a Growl Windows VBS for instructions on VB shell script. Thanks for the answer.
- 70 reads
- 1 comment
Hi guys! I need parameters for my project in Visual Basic. This will be done using VB script. Can you help learn about this NeoBook button library? Thank you very much!
- 80 reads
- 1 comment
Dear,
I am a windows 7 user. I'm quite new to visual basic. I would like to know how 2 create Activex dll in VB. I have no idea about it as I have said that I'm a novice to visual basic. Please help me with details.
Thanks
- 57 reads
- 1 comment
Hello, I’m trying to figure out how to make folder extension changes with vb6. I need to change the folder extension but I want to make sure the files are not corrupted once they are changed. Does anyone know how to change the folder extension with vb6?
- 53 reads
- 1 comment
I am looking for an employee information system source code written in visual basic 6.0. For the back end connectivity, it should be MS Access to store the data. I want this application to have features like adding a new employee, deleting employee information, update employee information, search an employee etc.
Database fields should hold information like employee name, employee number, address, phone number, gender, date of birth, date of joining, department.
Anyone please share with me the code of employee info system vb.
- 115 reads
- 1 comment
Which website displays a list of helpful tips about coding for prime number in Visual Basic? Is it also possible to choose all prime numbers in Microsoft Excel?
- 82 reads
- 2 comments
Hi all
I want to style my applications created in Visual Basic with the look and feel. Creating one from scratch is time consuming. Is there a software something like a Visual Basic Skin Maker or Creator? Where I can just choose from a range of different styles. My OS is Windows 7, just in case some software don't support Win 7.
Thanks !
- 64 reads
- 1 comment
I'm practically new to Visual Basic. As my first project, I'd like to create a stable 1 minute stopwatch in vb6, I'd like it to ping an event every 1 minute and be synchronized with the system clock. I'm using Visual Studio 2010 on OS XP 64 bit. Suggestions anyone?
- 51 reads
- 1 comment
Dear,
I'm a windows 7 user. I want to use Borland c builder enterprise edition on my PC. What are the minimum requirements to use it? I need to know in details.
Thanks
- 71 reads
- 1 comment
Experts! I would like to know if we can MSG RDP VBS. Can someone guide me on this? I will really appreciate it guys. I just need to get with this. Thanks so much in advance.
- 58 reads
- 1 comment
