Display :
Category: Visual basic
I want to create a simple program. I just need help in Visual Basic 2015. What do you mean by “naming convention?” Can you give me example for this? How to rename a control? Can you show me step-by-step in changing the properties of any specific control? Can you show me how to add codes in my program? How to save projects also in Visual Basic 2015? How to save files? What are the properties commonly used in textbox and labels? Any response will be appreciated. Thank you!
Please help me to understand the controls and events in VB 2015. What are the uses and when it is best to use the click, keypress, setfocus events in VB2015? What is also the use of click and change in label control? What are the functions of Activate and GotFocus in forms? What is the use of dblClick? What is the use of Timer() event in Timer Control? What do you mean by debugging? How to run the program in VB 2015 or VB 6.0?
Hi!
Is there any tool that I can use to interact with other Windows applications? What are the tools that I can use to access directories? I want to make an organized application, what are the tools I can used to organize or group the objects in my form? What is the difference between textbox and label? Can change the value of label at real-time? What is the use of timers in tool box? What is the best way to use it? What are the properties I can use to animate command buttons? Your answer is much appreciated! Thank you!
I would like to ask for the following information. What is the purpose of Properties Window? What are the attributes that I can use and change to modify my form in Visual Basic? What are the tools available in toolbox? What are the different steps in creating a simple program in VB 2015? Can you expound the steps and explain it to me? What are the things that I need to keep in mind in creating a program? Please help me with this. Thank you very much and have a nice day!
Hello!
I want to know more about Visual Basic before I start on coding? What is visual programming? What do you mean by event-driven programming? What is Visual basic? What do you mean of IDE in Visual basic? What are the uses of Events? What is the purpose of FORMS? What are the perfect way to utilize CONTROLS? Can you give me samples of controls that I can use in Visual Studio? What is the technique used to create GUI? What is GUI by the way? Please provide assistance. Thank you!
Hello!
What is a high level language? What is the difference between high and low level languages? What is a query? What do you mean by expert systems and artificial intelligence? What is Turing test? How does it work? Is there any machine that passed this test? What are databases? What is the hierarchy of data? I am quite confused, which one is bigger file or record? What is the proper word to use if am going to pull up your file or record? What is a 3GL Code? Can you help me with this?
I am new to programming and I want to know the basic. What is the meaning of programming? What are the categories of programming languages? What is a machine language and assembly language? What are the differences between this two? What is a source program? What is an assembler? Can you provide me any sample of this languages? What are binary digits? Is it different from our numerical digits? What is programming language? Can you please help me with this? Thank you!
I want to create a simple program. This program will ask first for your name, address, birthday and status. Once entered, we can punch a button that can summarize everything and stating the information provided and computing for your age. Can this be attainable to Visual Basic 2015? What are the objects that I need to use? Can you provide me explanation per line? What are the problems that you encountered? What are your suggestions on how I can improve this programs interface and dimension? Thank you very much and have a nice day!
I want to traverse a program that will give me values of 3 digits with the minimum value and maximum value. What are the objects that I need to use to make this work? Please explain to me the declarations per line if possible for better understanding. Please don’t provide me any links with your answer. I want to know how programs work and it is implemented. Can you give me alternative options for the solution? Thank you very much and have a nice day!
I want to create a program that can accept 3 numbers. Display it back with options like highest to lowest or vice versa. What are the objects I need to use to make this work? Can you please explain to me step-by-step or line-by-line how the program will work? Can you show me how to create .exe file out of this program. What are the possible or problems you encountered while doing this small program? Thank you very much and have a nice day!
